06:42 AM
Mar 19, 2016
06:42 AM
03:13 AM
Mar 28, 2016
03:13 AM
Hello Ben,
We have an Application Note for Ultrasonic Distance Measurement for Park Assist Systems. You can refer to this Application Note as a starting point, since it does not use the same ultrasonic transducer.
AN76530 - PSoC® 1 Automotive Ultrasonic Distance Measurement For Park-Assist Systems
A short answer is that we do not have an example for the HC-SR04. But the above mentioned AN works directly on the transducer, generating the ultrasonic signal from PSoC1.
After going through this AN, do let us know your questions.
Thanks and regards,
Sampath Selvaraj
