Glitch Filter - Variable Length
I want to edit the length of the Glitch Filter component at run-time. Is this possible?
I'm using the 8 - 256 length version of the component, so if I knew which register was used for the comparator I think I would be able to do this.
Pending any other solution, I'll just change the clock speed feeding the block.
