PSoC™ 5, 3 & 1
 Hi all,
While programming CYRF69103 using Miniprog3 Rev*A, i'm getting the following error!!
         Programming Terminated
         Detected SiliconID: "00 00 00 00" is not in database
    Kirangkr
Bob_Marlowe
Expert II
        I had the very same error a few weeks ago. File a technical MyCase and they will help you. The cause (with me) were some leftovers in the registry from former Creator installations which I could not remove (even not manually)
Bob
permanently having a very small reply window, no helps??
Bob_Marlowe
Expert II
Bob
 Hi Bob,
Thank you for your reply, could you be more specific!!
Kirangkr
Bob_Marlowe
Expert II
        I said: File a technical MyCase.
At top of this page go to "Support & Community->Technical Support->Create a MyCase"
Bob
ETRO_SSN583
Esteemed Contributor
This might be of some help -
www.psocdeveloper.com/forums/viewtopic.php
Regards, Dana.
 I got that message several times before. it happened to me when the programmer was not properly acquiring the device. Often I just have to unplug the programmer and/or reboot my computer other times I have to check device connections (if not using a cypress kit check power and SWD signals )
 Hi All,
Thank you so much for all your reply.
Kirangkr
