hello
i am using GitHub - AndresNavas/PSoC5_uGUI_SD_Sample: Sample and Test project of uGUI and SD-Card FatFs library... for my project with PSOC5 LP and https://www.buydisplay.com/default/lcd-5-ssd1963-tft-module-touch-screen-display-800x480-mcu-arduino display
i have connected display and psoc 5lp but only get the back light on not nay other things are showing on display
where i am making any mistake in code or connection? can someone help me?
how to connect display with psoc ? currently i am connecting as per pins in Design wide resources of psoc creator and supply and ground to display
also at present i am not interfacing sd card portion
PSoC 5LP
hello
solved the issue by adding this command and data lines
Display_WriteCommand(0x00B8);
Display_WriteData(0x000f); //GPIO is controlled by host GPIO[3:0]=output GPIO[0]=1 LCD ON GPIO[0]=1 LCD OFF
Display_WriteData(0x0001); //GPIO0 normal
Display_WriteCommand(0x00BA);
Display_WriteData(0x0001); //GPIO[0] out 1 --- LCD display on/off control PIN
Hi devyaniparmar.
You have to check the following:
Your VDD voltage level (3.3 or 5V)
In my example the LCD works at 3.3V and I'm using a CY8CKIT-050 (What PSoC or Kit are you using?)
Checking the PDF of your LCD, it's possible that you have a 5V version, so please be sure of that.
The pins on the PDF of your LCD (as your link suggest) should be connected as follows:
FOR JP2/CON1:
1. VSS to GND
2. VDD to VDD (remember to check if it's 3.3V or 5V)
3. /CS to D_CS
4. D/C to D_RS
5. E_/RD to D_RD
6. R/W_/WR to D_WR
7. E_RESET_NC to D_RST
8. TE to Open (Not connected to any pin in my project)
9~24. DB0-DB15 to DLow_DB and DHigh_DB respectly
25~32. DB16-DB23 must be tie to GND
33. RTP CS to T_CS
34. RTP CLK to T_CLK
35. RTP DIN to T_DIN
36. RTP DOUT to T_DO
37. RTP BUSY to Open (Not connected to any pin in my project)
38. RTP PEN to T_IRQ
39. BL_ON/OFF to D_BL
40. VSS to GND
So, check these connections and let me know!
Hope you can put it to work!!!
hello
thanks for your support
i am also using CY8CKIT - 050
my display is working on 5V
at present i am not using touch panel and sd card
so on JP2/CON1
33~38 is open and other pins are connected as you said above
also sd card is not connected
and gratefully i got white display only and after sometimes it is again in previous condition
is it problem of supply voltage? i checked on PIN2 of connector i got 4.27V
Hi!
Please check the VDD, 4.27V maybe not enough to move your display, so ensure 5V.
For your connections, may sure that P5 is DLow_DB and P2 DHigh_DB.
Regards!
hello
like from P5[0] to 9 and P2[7] to 24 respectively?
Hi.
Yes, P5[0] to 9, P5[1] to 10 ... P5[7] to 16; P2[0] to 17 ... P2[7] to 24
I did as per above
At now i am not using touch and sd card, it will create the problem ?
Please can you guide me to change the parameter?? I am new to this
Do you have any tutorial link for this set up of initialization?
clock speed down to 20Mhz
The Touch and SDCard shouldn't be a problem, just leave the pins open... But to get sure you can comment the lines that call the touch and SD functions.
For the LCD Panel setup and timing configuration, you'll need to have the LCD panel datasheet, I don't know if there's a tutorial or something for that, I'm sorry...
I you have the LCD Panel datasheet please share it and I could check what parameters you'll need to change.
ok
i have already comment the code which i am not using and also pins are open
here link to datasheet https://www.buydisplay.com/download/ic/SSD1963.pdf
tft module datasheet https://www.buydisplay.com/download/manual/ER-TFTM050-5_Datasheet.pdf
Please check this crystal:
Must be 10MHz!
Yes it is 10MHz crystal
And also it is 8080 parallel interface
You can check the timing information at the end of datasheet
Which page?
However in this link:
https://www.buydisplay.com/download/democode/ER-TFTM050-5_8080_16-bit_Resistive_Touch_Panel_Font_Chi...
They offer a Sample Code, in it I could check the configuration in the file SSD1963.h, so replace ugui_SSD1963.c in the PSoC project with the file attached and try again.
They also offer this schematic as a Sample:
So, as I see there, try leaving RESET (pin 7) open or Not connected.
i tried above all things
no changes
hello
OK Cool!...
So the LCD uses the internal BackLight control!....
Great, so please share some videos!
Yes
How to send video and image here?
I have to upload on youtube first?
Yes you can do a Youtube upload and then share the link...
hello
i will send video tommorow
here i have now new issue
image is cut in the half way as shown in attached image
what is the possible reason behind this?
Hi!
You have to take off the BMP header of the Image data. And check the size of the Image, in some cases I have to add or rest 1 pixel in the width image window.
Hello
Hight is 100,width 121
You mean i have to make width 122 or 119?
Also which converter you used for .dat file conversion?
Also one more thing, i want to interface Flash IC for image file storage ,do you have any idea for that?
I have W25Q128FV FLASH IC
Yes, try changing the width to 122 or 119...
I used the B2C converter by Segger, it's in the file that Cypress provide for emWIN http://www.cypress.com/file/131166/download
With it i convert the BMP to .C file.
For the Flash management you could use some similar management as I did with the SDCard.
hi andres
i have implemented flash chip mentioned above with psoc5lp
and i am writing the flash chip from the sd card and read and transfer image bytes to display
but i am not getting image properly, it is showing black and whit dots instead of actual colors of image
any idea behind this issue?
also how can i write fast to display, it is very slow loading
Hi. So cool!
About the Image you have to check that the BMP is RGB565 (16bits color format)
About speed, with 16bits BUS you should have a good speed in display, maybe your slow loading is because the memory data transmission. Try changing the frequency or bitrate.
hello
i got the image from flash as per attachment
which converter to use for .dat file?
i changed the frequency , but didnt get the required result
which one will be the ideal frequency for my flash ic,sd card and display?, do you know how can i decide this?
HI.
I'm sorry but you have to try and look for the best result.
However the SDcard speed is really slow, so if you are streaming the image from SD to Display you will see the progress, It won't be fast.
To do what you need you will need to double buffer the graphics, unfortunately the SSD1963 hasn't enough memory to double buffer, neither the PSoC RAM could be enough... So... I really don't know if you can do what you want with your actual hardware...
For me works great because I don't have timing restrictions and I can wait for the Image loading progress...
hi
okk
do you know which one fit best for me?
any suggestion ?
thaks
I'm sorry... But you'll have to search in the market...
Okay
No problem
Nd thank you so much for support
hi
i used DMA ping pong, and as we can use 2 arrays to store the value,
can i use those to array to write image on display one after one from sd card?
like first rxBuffer will store values of first 2 bytes from SPIM(sd card) and when it is full rxBuffer1 will store the next bytes, so now i have 2 array of image value
does it possibe? : when first buffer is filled it will write it to lcd and when write is completed,rxBuffer1 will be written to lcd, during both write period DMA read the rx buffer value of SPIM and all process will repeat until whole image write?
if above is possible:
1)how can i write 2 arrays using f_read from the sd card? i mean to say that as in code pt = f_read(&fileO, rxBuffer,200, &br); will give me only value of rxBuffer not the value of rxBuffer1, how can i get the rxBuffer1 value ?
any idea?
also you said double buffer is not possible with this device because of my above doubt?
sorry for my confusing english
how to convert image to .dat?
now i am giving 5V properly, but no changes on display
If all the connections are OK and the supply is OK and you're getting a white screen, maybe the configuration parameters of your specific LCD panel, you have to check the values to setup the LCD timing, Vertical and Horizontal sync....
The values are in the file ugui_SSD1963.c function Display_Init()
You have to check your specific LCD panel datasheet timing configuration.
Also try reducing the speed clock of the LCDIntf block to 20MHz
hello
my connection for data lines from connector to CY8CKIT-050 are correct?
9~16 - P5[0]~P5[7]
17~24 - P2[0]~P2[7]
