PSoC™ 5, 3 & 1
JaRa_1183061
10 replies posted 10 sign-ins 5 replies posted
I am using existing libraries and I am getting this error Plus.h (in my main file) No such file or directory exist.  Then I moved the main file to the same folder as Plus.h file, then the issue goes to the project.h file.
How do I ensure that all files have access to each other.
Alakananda_BG
Moderator 250 sign-ins 250 replies posted 100 solutions authored
Can you please let us know which IDE you are using?
If you are using PSoC Creator, you should include the directories in Build settings--> Compiler--> Include additional libraries. There you need to give the path name of where the plus.h exists.
Alakananda
