during build, I got the following in output tab
HDL Generation...
Synthesis...
Tech Mapping...
Error: mpr.M0022: "Net_232" is not a top level pin. Not expecting internal three-state signals. (App=cydsfit)
ADD: mpr.M0037: information: Unused pieces of the design have been optimized out. See the Tech mapping section of the report file for details.
* C:\Users\Larry\Documents\PSoC Creator\LMA Amp Rack APNA Simulation\crosspoint switch test.cydsn\codegentemp\crosspoint switch test.rpt (Tech mapping)
Dependency Generation...
Cleanup...
Error: fit.M0050: The fitter aborted due to errors, please address all errors and rebuild. (App=cydsfit)
--------------- Build Failed: 08/11/2022 10:13:49 ---------------
and the only error in the report file:
Converted constant MacroCell: \SPIM:BSPIM:so_send_reg\ from registered to combinatorial
Converted constant MacroCell: \SPIM:BSPIM:mosi_pre_reg\ from registered to combinatorial
<CYPRESSTAG name="Global Clock Selection" icon="FILE_RPT_TECHM">
Digital Clock 0: Automatic-assigning clock 'SPIM_IntClock'. Fanout=1, Signal=\SPIM:Net_276\
Digital Clock 1: Automatic-assigning clock 'Clock_1'. Fanout=1, Signal=Net_30
</CYPRESSTAG>
questions:
1) what is mpr.M0022 ?
2) how do i find "Net 232" ?
3) what is the actual problem that needs fixing ?
archived files attached
PSOC5 LP MCU
Larry,
You've assigned your SPI master to be Data Lines: Bidirectional.
However you attached the sdat terminal on the SPIM component to a Digital output pin
not a Digital Bidirectional pin.
If you change your xp_data to a Bidirectional pin,
The error goes away.
Larry,
thank you
and the first question: 1) what is mpr.M0022 ? (are error codes expounded upon somewhere?)
ultimately: are error codes expounded upon somewhere?
