PS C:\Users\Avinash\OneDrive - hyderabad.bits-pilani.ac.in\Documents\Python Scripts> python Potentiostat_GUI.py
Measurement frequency: 500.02083420142503 Hz
Exception in Tkinter callback
Traceback (most recent call last):
File "C:\Users\Avinash\AppData\Local\Programs\Python\Python310\lib\tkinter\__init__.py", line 1921, in __call__
return self.func(*args)
File "C:\Users\Avinash\OneDrive - hyderabad.bits-pilani.ac.in\Documents\Python Scripts\Potentiostat_GUI.py", line 228, in Send_CV_Settings
self.user.set_Scan_rate(_scan_rate)
File "C:\Users\Avinash\OneDrive - hyderabad.bits-pilani.ac.in\Documents\Python Scripts\Potentiostat_userinput.py", line 46, in set_Scan_rate
self.comm.usb_write(scan_rate_formatted) # Send command
File "C:\Users\Avinash\OneDrive - hyderabad.bits-pilani.ac.in\Documents\Python Scripts\Potentiostat_communication.py", line 76, in usb_write
self.ep_out.write(message)
AttributeError: 'NoneType' object has no attribute 'write'
Plot title is stored.
Plot legend is stored.
Cyclic Voltammetry initialization has started.
File "C:\Users\Avinash\OneDrive - hyderabad.bits-pilani.ac.in\Documents\Python Scripts\Potentiostat_GUI.py", line 273, in Start_CV_scan
self.user.run_CyclicVoltammetry()
File "C:\Users\Avinash\OneDrive - hyderabad.bits-pilani.ac.in\Documents\Python Scripts\Potentiostat_userinput.py", line 113, in run_CyclicVoltammetry
self.comm.usb_write("R")
Hi @shuvra1 ,
I see that this is related to https://journals.plos.org/plosone/article?id=10.1371/journal.pone.0201353. We recommend you to get in touch with the author(s) of the dissertation for the dissertation specific implementation/details. The GUI was not developed by Infineon Technologies and the errors are with respect to the GUI developed by the authors. So I highly recommend you to contact the authors for the same.
Nikhil
Hi @shuvra1 ,
Nikhil
