PSoC™ 5, 3 & 1
I'm using the psoc 5LP protokit.
Does hooking up a stepper/DC motor always require a motor driver? Or do I just need to use a pwm or LUT? Does the voltage requirements of the motor change this answer?
Tom
Bob_Marlowe
Expert II
The digital outputs of a PSoC will not be able to drive a stepper motor directly, so you eill always need a driver IC.
Bob
