bezobraznic
25 sign-ins 10 likes given 10 sign-ins
Hello all!
How to dinamicaly change CAN ID of the TX FULL message of CAN component?   Thanks!
bezobraznic
I found it!
CAN_SET_TX_ID_STANDARD_MSG(i, id);  !!!
SampathS_11
250 sign-ins 250 solutions authored 5 questions asked
Kindly refer to Changing CAN receiver id.
Sampath Selvaraj
No. I need to change ID of TX full message, that is allready configured in CANcomponet TX section. Thanks.
Hi AlMe_962021​,
You should still be able to change the ID of the Full mailbox using the AMR and ACR registers. You can directly write into the respective registers with the correct filter settings.
For example, the following code changes the filter settings of Mailbox0 as 0x003.
#define AMR (0x001FFFF9)
#define ACR (0x00600000)
CY_SET_REG32( 0x402E00B0,AMR);
CY_SET_REG32( 0x402E00B4 ,ACR);
Refer the device register TRM for the correct register location for the respective mailboxes.
Bragadeesh
Bragadeesh
bezobraznic
I found it!
