We are using PSoC 5LP. In our workspace, there is one bootloader project and one bootloadable project, and they are link together.
We use this tool to do PSoC FW update:
Before doing PSoC FW update, we need to call Bootloadable_Load() from bootloadable project to put PSoC in bootloader mode.
We found that, after setting PSoC to bootloader mode (calling Bootloadable_Load()), PSoC stays in bootloader mode only for a couple seconds, then it goes out of bootloader mode. So if our script is quick enough, FW download to PSoC succeeds; otherwise it fails and I can tell the PSoC returns to normal application mode.
My questions are: Why bootloader mode does not stay for longer, and how to make it in bootloader state longer?
Winston
PSOC5 LP MCU
Hi @yaga_3967241 ,
Generally if we call Bootloadable_Load() it should wait in bootloader forever.
You can see from the below flowchart that it will wait forever in the bootloader once Bootloadable_Load() is called.
Hi @yaga_3967241 ,
Hello.
Change the default setting in the bootloader project. Change bootloader component from 2 seconds to whatever timeout you need. Right-click on bootloader component, select config... and change the Wait for command time (ms). Make sure there is a check-mark in the box for "Wait for command".
Then build, download, the bootloader. Also re-build bootloadable project and download it. Then test the new bootloader timeout.
Good luck with your project.
