Data Acquisition System with 32 channel
Hi All
Please help me in doing a Data Acquisition system control board with PSoC, I am a new developer .
Please mention the steps through which I should start doing this.
Thank you all
Have a wonderful day !!!
Bob_Marlowe
Level 10
Level 10
Welcome in the forum-
The steps are quite easy:
Order a CY8CKIT-059 Prototyping Kit from Cypress or from your local distri.
While waiting for the kit to arrive download and install PSoC Creator
Watch some of the videos to get a feeling for how PSoC design works
Create a Project and put in it the required components as
  • AD converters
  • Analog multiplexors
  • Communication interfaces
  • IO pins
Connect all these with wires just as a usual CAD software
Write some C-language code to access the components and send acquired data over the interface
Start debugging your project
Lean back and smile 😉
Bob
Bob_Marlowe
Level 10
Level 10
  • AD converters
  • IO pins
Bob
Hi
Thanks alot Bob 🙂
I installed PSoC Creator and designed the project.but my query is how can I upgrade a board which is working with  microcontroller  to a board with PSoC .Please guide me .How can I achieve it
Hi Bob
Hello!!
My requirement is to build a board for communication from the Data acquisition board .
I have done a schematic but I tried to replace the microcontroller with PSoC 3,can you help me in completing the schematic!! Its a eagle file.  I can't attach it .
so what should I do to complete the design
Tanvi
Bob_Marlowe
Level 10
Level 10
"how can I upgrade a board which is working with  microcontroller  to a board with PSoC"
When you are talking about a pcb there will be no chance to drop in a PSoC into the current design.
When you are talking about to replace an existing design with a more modern one, then you are done to 90% (providing test phase completed)
What remains is making a new pcb.
Bob
Hi All
Which the best suited PSoC for Data acquisition System  ?Please Comment ...
Have a Nice day !!!!!
Bob_Marlowe
Level 10
Level 10
Fastest will be PSoC5. Use the above mentioned Prototyping kit.
Bob
Thank you so much Bob
Hi Bob
I received the prototyping kit from cypress.
please guide me.can you pass me your mail id
Bob_Marlowe
Level 10
Level 10
Sorry, but I do not answer per mail.
Did you already watch the videos showing how to design with PSoCs?
Bob
Yea
Bob_Marlowe
Level 10
Level 10
I would suggest to start building up one channel. What is the interface? analog? Precision needed?? Voltage range??? Needed frequenxcy resolution??What are you going to do with the resulting value?
Bob
Hi Bob
Good Morning
Yea I started with one channel. Analog interface is what I required. This is data acquisition from a mass spectrometer
Hi Bob
In my project what I am doing is after retrieving data the data is provided to PSoC  and PSoC will be providing the data to DAC for analog output, what is the suggestion for that ?
Bob_Marlowe
Level 10
Level 10
Using the DAC will do what you need to.
Bob
