08:38 AM
Dec 04, 2016
08:38 AM
I have been working on PSoC 5LP for a while, PSoC is quite powerful but it takes a lot of efforts to know the details... The DFB is another complex unit. I disassembled the FIR code generated by the Filter component, so I can test it with the DFB Assembler. I put some comments on it based on my understanding with the DFB module, I might be wrong... Here is the assembly code:
// Copyright 2008-2013, Cypress Semiconductor Corporation. All rights reserved.// Filter coefficients are stored in RAM-Barea acu // 16 taps dw 0x0F0F // mreg dw 0x0000 // lreg dw 0x0000 // initial value for ACU-A.reg area data_b // 16 taps dw 0x00E168 dw 0x00432A // add another 14 taps here... initial: // Enable modulus arithmetic acu(setmod,setmod) dmux(sa,sa) alu(set0) mac(clra) acu(clear,clear) dmux(sa,sa) alu(hold) mac(hold) jmp(eob, wait_for_data) wait_for_data: // Wait input from stage-A(in1) for the next element acu(hold,hold) dmux(sa,sa) alu(hold) mac(hold) jmpl(in1,load_data) load_data: // Load (mreg,lreg) with (acu[0],acu[1]) acu(loadm,loadm) addr(0) dmux(sa,sa) alu(hold) mac(hold) acu(loadl,loadl) addr(1) dmux(sa,sa) alu(hold) mac(hold) // Open the channel from stage-A(addr(1)) to RAM-A at mux1a
acu(hold,hold) addr(1) dmux(ba,sa) alu(hold) mac(hold) // Write data to RAM-A, modify mux, load acu-A with acu[2] acu(read,clear) addr(2) dmux(sra,sra) alu(setb) mac(clra) write(da) jmp(eob, calc) write_bus: // Write acu[2] with acu-A.reg acu(write,clear) addr(2) dmux(sa,srm) alu(setb) mac(hold) acu(hold,hold) dmux(sa,sa) alu(hold) mac(hold) // Write shifter output to the bus' holding register A with addr(1) acu(hold,hold) addr(1) dmux(sa,sa) alu(hold) mac(hold) write(abus) jmp(eob, wait_for_data) calc: // Multiplication acu(incr,incr) dmux(sra,srm) alu(setb) mac(macc) jmpl(eob, acubeq, write_bus)
Labels
PSoC 5LP
10:24 AM
Dec 04, 2016
10:24 AM
Nice work, code sure looks correct as well as the comments. I assume you have run the code through the simulator.
Of course for standard filters the Filter component is easier to use, but for special needs and making your own filter variants this is a good starting point.
