Would you recommend a Cypress MCU (with a specific part number)
that can be used for Fan motor controller with
Hall sensor feedback and the needed specs below?
Specification:
=pin support:
-L1 : Exciter coil
-L2 : Exciter coil
-VDD, GND : Hall sensor Power
-FG : Hall sensor Power output
=shall work along with:
-Fan motor performance (rpm): 10000 RPM
-Power supply voltage (V) : AC 120V (DC 169V)
This Fan motor control system is for the Temperature control unit.
Thank you for your help and recommendations.
Sincerely,
Ben.
PSoC1 MCU
PSoC3 MCU
PSoC5 LP MCU
Hello @hoop4g
On the landing page of the CY8CKIT-037 you would notice that there are a certain set of code examples of this kit. The code examples include both Sensored and Sensorless BLDC Motor Control. CY8CKIT-037 PSoC® 4 Motor Control Evaluation Kit Guide provides detailed information about each of the available code examples.
The Code examples use the CY8C4245AXI-483 device, therefore I guess you can use the same device for your application. The datasheet of the device can be found on this page: CY8C4245AXI-483
Cypress also has an Evaluation board: CY8CKIT-042 that comes with this device. You can use this for initial testing.
Best Regards
Ekta
Hello @hoop4g
You can use the CY8CKIT-037 kit by cypress as a reference: https://www.cypress.com/documentation/development-kitsboards/cy8ckit-037-psoc-4-motor-control-evalua...
Best Regards
Ekta
Hello Ekta, I saw the kit description and I don't see the Cypress MCU included to the BOM.
Please provide Cypress MCU part number with the datasheet.
1. Part number : clear Cypress microcontroller part number that has pin support of:
-L1 : Exciter coil
-L2 : Exciter coil
2. datasheet to the part.
Hello @hoop4g
Best Regards
Ekta
CY8C4245AXI-483 is a bit beyond the spec. It costs almost $2 dbp, twice the price of the target replacement.
Currently the customer is using infineon's XMC1302-T038X0200
XMC1300 Data Sheet (infineon.com)
Could you recommend what can be equivalent from Cypress MCU from Infineon's XMC1302-T038X0200?
Hi @hoop4g
Please use the filter at the following link: Product selector
You can select the exact features you are looking for from the left-hand panel and will recommend a list of devices that meet your requirement.
You can then choose a device that suits your needs.
Best Regards
Ekta
