benkim
Distributor - Avnet (South Korea)
First like received 50 sign-ins 25 sign-ins
Would you recommend a Cypress MCU (with a specific part number)
that can be used for Fan motor controller with
Hall sensor feedback and the needed specs below?
Specification:
=pin support:
-L1                 : Exciter coil
-L2                 : Exciter coil
-VDD, GND : Hall sensor Power
-FG                : Hall sensor Power output
=shall work along with:
-Fan motor performance (rpm): 10000 RPM
-Power supply voltage (V) : AC 120V (DC 169V)
This Fan motor control system is for the Temperature control unit.
Thank you for your help and recommendations.
Sincerely,
Ben.
Ekta_N
750 replies posted First like given 250 solutions authored
Hello @benkim
On the landing page of the CY8CKIT-037 you would notice that there are a certain set of code examples of this kit. The code examples include both Sensored and Sensorless BLDC Motor Control. CY8CKIT-037 PSoC® 4 Motor Control Evaluation Kit Guide provides detailed information about each of the available code examples.
The Code examples use the CY8C4245AXI-483 device, therefore I guess you can use the same device for your application. The datasheet of the device can be found on this page: CY8C4245AXI-483
Cypress also has an Evaluation board: CY8CKIT-042 that comes with this device. You can use this for initial testing.
Best Regards
Ekta
Ekta_N
Hello @benkim
You can use the CY8CKIT-037 kit by cypress as a reference: https://www.cypress.com/documentation/development-kitsboards/cy8ckit-037-psoc-4-motor-control-evalua...
Best Regards
Ekta
benkim
Hello Ekta,  I saw the kit description and I don't see the Cypress MCU included to the BOM.
Please provide Cypress MCU part number with the datasheet.
1. Part number : clear Cypress microcontroller part number that has pin support of:
  -L1                 : Exciter coil
  -L2                 : Exciter coil
2.  datasheet to the part.
Ekta_N
Hello @benkim
Best Regards
Ekta
benkim
CY8C4245AXI-483 is a bit beyond the spec. It costs almost $2 dbp, twice the price of the target replacement.
Currently the customer is using infineon's XMC1302-T038X0200
XMC1300 Data Sheet (infineon.com)
Could you recommend what can be equivalent from Cypress MCU from Infineon's XMC1302-T038X0200?
Ekta_N
Hi @benkim
Please use the filter at the following link: Product selector
You can select the exact features you are looking for from the left-hand panel and will recommend a list of devices that meet your requirement.
You can then choose a device that suits your needs.
Best Regards
Ekta
