Apr 28, 2010
03:29 PM
Apr 28, 2010
03:29 PM
I've created a bootloadable project and if I try to build the project I get the following error:
Error: cyp3isrpatcher: An item with the same key has already been added.
The command 'C:\Program Files\Cypress\PSoC Creator\1.0\PSoC Creator\bin\cyp3isrpatcher.exe' failed with exit code '1'.
Any suggestions?
Rolf - CYPros
Labels
PSoC 3
02:36 AM
Apr 29, 2010
02:36 AM
I figured out that disabeling Linker Code Packing at the Compiler Optimization tab solved the issue.
Rolf
