hello, the PSOC creator software seems to have updated the firmware on the kitprog so now it shows up as CMSIS-DAP/246038 instead of kitprog 2.0 or 2.21 (I forget which) like I had before. how do I revert/change the kitprog firmware back to what is was before? I would like to use the USB-UART that was available before.
ispn:39618:1:0
l1:314:1:0
duno,
Is the "Status" LED on the KitPRog board throbbing (blinking with fade near the USB connection)?
If true, you will also find a new Disk Drive in Device Manager with a name that includes "KitProg".
To get out of this mode, while it is powered on, press the "Boot/TARGET RST" switch for 5 secs. It will stop blinking and be ON continuously. You should also see the COM enumerated USB port of the KitProg.
duno,
