Sep 30, 2021
03:55 AM
Sep 30, 2021
03:55 AM
I am using your CY8C5868 PSOC, use it sample lmt84(temperature sensor) P3.7 temperature as below configuration.
But FW can't capture stable value, use the scope capture the lmt84(temperature sensor) output signal is pull down in about 100KHZ. If I disconnet the output pin to P3.7, the lmt84 output signal is stable.
Kent
Labels
02:02 AM
Oct 11, 2021
02:02 AM
Hi Kent,
See the schematic below. Keep the opamp in follower mode in configuration. Make sure you call Opamp start in the firmware.
Vasanth
Vasanth
