LuNo_297436
First solution authored 10 replies posted 10 questions asked
Hi every one!
Is there a way , in assembler, to define constant tables with DWORD (32 bits)values on it?
Or the only way is splitting in 16 bit values?
i.e.
High_Word_Tab:
dw 0x0000
​Low_Word_Tab:
dw  0xffff
Luis
SampathS_11
250 sign-ins 250 solutions authored 5 questions asked
There is no assembler directive to define a table in terms of 32 bit values. You can also define the 32-bit value table using the Define Byte directive also. When accessing this table, we must make sure we access on the correct 4-byte boundary.
SampathS_11
