I have a psoc creator project for the CY8C5488 part. The project is fully operational. Now I need to make it bootloadable, so I added Bootloadable_V1_60 module and configured it as directed by the datasheet. I get a build failure:
Error: pft.M0101: Unable to generate metadata file:
Dependency Generation...
Cleanup...
Error: fit.M0050: The fitter aborted due to errors, please address all errors and rebuild. (App=cydsfit)
--------------- Build Failed: 01/22/2019 11:11:20 ---------------
I cannot find an explanation for this type of failure that could point to the reason. I saw related blog where someone had the same failure for a "simple" project, and the way he solved is by re-creating the project from scratch including the bootloadable object. My project is advanced, to do this I suspect would take a lot of work. Any suggestions regarding alternatives? I can attach the source code if necessary. Thanks.
Got the bootloadable code to build successfully. The problem was that I first used the bootloader .hex and .elf files generated by someone else to create a bootloadable version of my code. So, when I built that bootloader on my IDE and used the resulting .hex and .elf files, the bootloadable code build worked. Thanks!
Hi
You can browse the below linker about the bootloader and bootloadable:
1: http://www.cypress.com/file/45346/download
2: http://www.cypress.com/documentation/application-notes/an84401-psoc-3-and-psoc-5lp-spi-bootloader
Can you attached a simple project which can reproduce your issue in this forum?
Today I will create a simple project to see if I get the same behavior, and report back. Thanks.
