xRocket
First question asked Welcome!
The suggestions window should show TMR_100ms_Start. I have reinstalled but the problem is still there.
Vasanth
Moderator 250 sign-ins 500 solutions authored First question asked
Could you try generating the code for the component using the following option
If that does not solve the issue, could you make sure the component name is being searched correctly?
Vasanth
Vasanth
Vasanth
BiBi_1928986
Level 7
250 replies posted 250 sign-ins 100 solutions authored
Level 7
Hello.
Unless this has changed in newer versions of Creator, it's case sensitive.
Try typing: TMR_100MS_START or TMR_100MS_Start
And, Vasanth's suggestion should also work.
