AlVa_264671
25 sign-ins First like given First like received
Hi
I would need help with the following compiller error:
Proj.M0120:Builderror.The command'arm-none-eabi-gcc.exe failed with exit code'1'
None of the same question I found on the comunity  worked for me in this case.
Bob_Marlowe
Level 10
Level 10
You have some multiple definitions of variables (i.e recivedByte). Go through the messages in the output window.
Try to get rid of all the warnings, some might be errors.
Bob
Bob_Marlowe
Level 10
Level 10
Bob
Thank you very much Bob
On Wed, Nov 1, 2017 at 11:17 AM, user_1377889 <community-manager@cypress.com
