Communication between PSoC 3 and Raspberry Pi using CAN Bus Protocol
Hello everybody,
i'm attempting to connect psoc 3 with raspberry pi with can bus protocol. my psoc connected with mcp 2551 and raspberry pi is connected with mcp 22515 and 2551.
but i'm still confuse about how to communicate between those devices,
can anyone please share your experience if you're done with that case?. thank you so much in advance!
ShanmathiN_06
100 replies posted 50 replies posted 25 replies posted
You can navigate to PsoC creator: File-> Code example and refer to the following two CEs.
CAN_Basic_Example
CAN_Full_Example
The above code examples would help you to send and receive data using CAN protocol, from PSoC3. I hope this helps.
Shanmathi
ShanmathiN_06
CAN_Basic_Example
CAN_Full_Example
Shanmathi
Please attach the project that you had used to program PSoC.
Could you please probe the CAN bus and share your scope shots?
Shanmathi
