I know there's a clear Eeprom api,  however, I was wondering if there is anyway to clear a device's eeprom via  PSoC Creator when programming the chip?
Thanks for any advice
Bob_Marlowe
Level 10
Level 10
You have the opportunity to specify the EEProm contents when programming the chip. Use the .cydwr view and select "E2 EEProm" view. You may even load/save the modified area from/to a file.
Bob
Thank you. That helps a lot.
