How can I change the Delta Sigma ADC Buffer mode configuration during run time? I have different kind of sensors:
0-5V with the ADC buffer in "Bypass Buffer" mode
+/-15mv with the ADC buffer in "Level Shift" mode
The ADC_SelectConfiguration() should change the ADC configuration but not the buffer options. I also added a delay to let the change take place before to start the conversion (CyDelayUs(50);)
Is there anything I should add to select different configuration for my buffer?
Thank you and have a great day
PSoC5 LP MCU
There is no component level API to change the buffer mode of the ADC dynamically. But if you check the device register TRM , you can see the same settings are controlled using Delta Sigma Modulator Buffer Register 0.
Vasanth
Vasanth
Thank you,
Does it mean I should manually update the Delta Sigma ADC Buffer mode's register because the ADC_SelectConfiguration() leave that register untouched when I select a new configuration?
Daniel,
Normally it is recommended to use the API calls to control the HW. Since in your case, there is no API call to modify the Buffer mode: options you will need to create your own API call.
The downside with this method in the future is if Infineon decides to control this register in later API calls of an update component version, your API may become obsolete and may not work as expected.
