May 04, 2016
09:05 AM
May 04, 2016
09:05 AM
Hi everyone,
I'm using capsens with 2 channels 28 capsenses.
For my application I need to use Vdac 125 --> 2V and Current qsource 32uA
When I compile I have a warning that i don't understand.
I"m using a PSOC 5 with a 3.3v supply, so if I use 2V Vdac I am normaly in the range.
Thank you
Labels
PSoC 5LP
11:34 AM
May 04, 2016
11:34 AM
Please post your project.
May 04, 2016
01:04 PM
May 04, 2016
01:04 PM
What you see is not a warning, just a notice. The DAC thats used by the CapSense component has a range of 0-4.08V (which is hardwired). So with a Vdda of 3.3V you get the notice that you cannot use the full range. Since you don't need it, its not relevant for you.
The actual warning that you get is that the variable 'whoami' is not used in your code (so its probably never read).
