Ever wondered how you could shape the future in collaboration with others? Join us at OktoberTech Asia Pacific and get inspired. Click here to sign up FREE of charge.
        Are there any known issues with pins no longer working for capsense after being used for digital I/O? I have the PSoC Development kit and accidently assigned a digital I/O function to P0.5 and then corrected the assignment back to capsense function...the capsense function for that port no longer functions...I can reassign it to another pin and the functionality works...if I assign back to P0.5 it will not work...I assigned P0.5 for digital functions and it works fine for digital I/O...Any suggestions/workarounds?
        Smuraski,
Is their any chance that you have P0[5] wired to something on the development kit's breadboard? You should have no issues assigning a CapSense pin with a different functionality, and then later setting it back.
Bobby
You can try like this: First make the pin properties as default in pin properties window. and then reassign the pin to capsense into the capsense wizard. then I Think it should work.
regards,
Sheshmal
