I added CyPmSleep () to my program with reference to the sleep timer sample code.
But did not wakeup.
As a result of investigating the cause, it was found that DieTemp_Start () does not wake up
Executing DieTemp_Stop () had no effect
I want to measure die temperature and sleep
Is there a solution
device:CY8C5888LTI-LP097
PSoC Creator 4.2
DieTemp Ver.2.1
SleepTimer Ver3.2
I'm sorry.I am inconvenient in English.
PSoC 5LP
Kono-san,
Could you refer DieTemp_BasicTest code example in PSoC Creator?
DieTemp_Start() should be called pair with DieTemp_QueryDieTemp().
If DieTemp_Start() is called successfuly, SPC(system performance controller, ) will be locked and other resource may not be able to use SPC.
So it requires to call DieTemp_QueryDieTemp to unlock SPC to make sure system can work well.
So in this case, if you have read the DieTemp_BasicTest code example, you will find it doesn't need to call DieTemp_Start() before while loop(it will be called in DieTemp_GetTemp(&temperature), also the DieTemp_QueryDieTemp()) .
Kono-san,
As per my understanding, the question is: after wake-up, DieTemp can not work. Is it right?
Could you share the project with using attachment?
Hi Ryan
No, that does n’t mean
Sorry for the bad explanation
This code works
int main()
/* Enable global interrupts */
CyGlobalIntEnable;
SleepTimer_Start();
CyPmSaveClocks();
CyPmSleep(PM_SLEEP_TIME_NONE, PM_SLEEP_SRC_CTW);
CyPmRestoreClocks();
But this code doesn't work
Do not wake up from sleep
int main()
CyGlobalIntEnable;
DieTemp_Start() ;
DieTemp_Stop() ;
SleepTimer_Start();
CyPmSaveClocks();
MaKo,
You're missing something:
int16 temperature;
DieTemp_Start() ;
DieTemp_Stop() ;
// temperature should now have your dietemp.
Unless I misunderstood your question, this should return a dietemp.
Len
HI Len,
thank you for your comment
I'm sorry but that doesn't mean that
The problem is that PSoC cannot wake up
Execute DieTemp command before sleep command
I experimented with the following code
int main()
CyGlobalIntEnable;
Pin_LED_write(0);
#if 0
int16 temperature;
DieTemp_Start() ;
DieTemp_Stop() ;
#endif
SleepTimer_Start();
CyPmSaveClocks();
Pin_LED_write(1);
#if 0 : LED Light on = wake up
#if 1 : LED Light off = can't wake up
If DieTemp_Start() or DieTemp_GetTemp(&temperature) is executed Even once before the sleep command
It becomes impossible to wake up
MaKo,
I now understand your issue. I'll download your project. Hopefully I'll have a solution/reason in the morning.
Len
Update 1: If I program the PSoC with DieTemp active the LED doesn't blink (mode 1). If I debug the code, the LED blinks (mode 2).
Still digging in ...
Update 2: In mode 2, I receive a short pulse from the SleepTimer about every 4 ms. In mode 1, nothing. No pulses.
Update 3: Hopefully someone from Cypress is monitoring this discussion
New information
There appears to be an unintended interaction between the following code sequence:
DieTemp_1_Start() ; ... CySpcGetTemp() {
CY_SPC_CPU_DATA_REG = CY_SPC_KEY_ONE;
CY_SPC_CPU_DATA_REG = CY_SPC_KEY_TWO(CY_SPC_CMD_GET_TEMP);
CY_SPC_CPU_DATA_REG = CY_SPC_CMD_GET_TEMP;
and
CyPmSleep() {
CY_PM_WFI;
if DieTemp_1_Start() is removed, the ILO sources to the SleepTimer properly.
if DieTemp_1_Start() precedes CyPmSleep(), it appears the ILO is effectively disabled while in CyPmSleep() preventing SleepTimer terminal counts.
Len.
Len,
Thank you for testing
I see!
It means that SleepTimer doesn't work
rather than not wake up from sleep.
me too
Kono-san,
Ryan
I carefully read Die Temperature's Component Datasheet
I found this description
Note that the device should not enter low power modes during temperature measurements. After calling DieTemp_Start() you should wait for the DieTemp_Query() API to report the status of the request that is different from CYRET_STARTED. For more information see the DieTemp_Query() API description.
So if I did the DieTemp code like this, it worked fine
After this I was able to wake up from sleep
I could get the temperature
DieTemp_Start() ;
while(CYRET_STARTED == DieTemp_Query(&temperature));
DieTemp_Start() ;
The reason for running twice
DieTemp_Query API Description:
The Die Temperature reading returned on the first sequence of DieTemp_Start() followed by DieTemp_Query() can be unreliable, so you must do this sequence twice and use the value returned from the second sequence.
Thank you
the problem seems to be solved.
If Ryan answered your question correctly, please select "Correct Answer" on his posting to close this discussion. This will help others with a similar problem if they are looking for a solution to try.
Len
Thank you for the advice.
I selected "Correct Answer"
Thank you very much for answering
Ryan,
Apparenty ...
DieTemp_Start() ;
DieTemp_GetTemp(&temperature);
DieTemp_Stop() ;
... is not the functional equivalent as:
DieTemp_Start() ;
DieTemp_Start() ;
.. regarding access to low-power modes.
However ...
... does work!!!
It appears when using DieTemp_GetTemp(), DieTemp_Start()/DieTemp_Stop() is not necessary.
Len
