MiBe_333556
First like received
I get an error when compiling a Math functions with an argument such as y=sin(x) using a PSoC 5LP chip.
prj.M0120: Build error: undefined reference to `sin`.
Is there a way around this?
Mike
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
Beta tester First comment on KBA 1000 replies posted
I needed add m in both compiler and linker config
Attached is a trivial sin value print out program using CY8CKIT-059, just for compiling reference.
moto
MotooTanaka
Level 9
Level 9
moto
Thanks Moto that solved the problem. It worked with just adding the m to the Linker Config.
Thanks again, Mike
