PSoC™ 5, 3 & 1
 Hi guys,
I am confised about CY8CMBR3116 programmer. Can I program it with CY3217 or CY3210 mini programmer.
What is your suggest to program CY8CMBR3116.
Second question:
I know CY3210 mini programmer is old version. (CY3217 is new). But I want to use CY3210 to program CY8C21x34 (CY8C21434-24LTXI). It is possible?
ETRO_SSN583
Esteemed Contributor
The miniprog3 for -
www.cypress.com/     Capsense user guide
www.cypress.com/     Programming specs
The Miniprog1 in the 3210 kit can program the CY8C21434-24LTXI
Regards, Dana.
ETRO_SSN583
The miniprog3 for -
Regards, Dana.
Thanks Dana,
Your post explains everything clearer.
I want to ask you something. I will use cypress cpu(CY8C21434-24LTXI) and cypress CapSens(CY8CMBR3116). For improve hardware and software, I'm looking for the appropriate KIT. I saw this KIT - CY3280-BK1 Universal CapSense Controller - Baic Kit1(http://www.cypress.com/?rid=3475). Is it right decision? What is your suggest?
NOT:This KIT has CY3240-I2USB board and CY3210 MiniProg1 Programmer. I think I can program cypress cpu and cypres CapSens with these boards. Correct?
Thanks for your help
Regards.
ETRO_SSN583
Can you describe a little more about what the overall project functionality is ?
Its hard to make recomendations w/o knowing the overal goals. Reason I ask is
there is several families that have CPU + Capsense, like PSOC 4, 5LP, 3, 4M
that can also perform capsense. And do analog measurements, general CPU
control, serial links, graphic display control, so much more.
Regards, Dana.
 Thanks Dana. You are so helpful.
I am designing a touch panel. Touch panel will send button data with UART.(there will be 12 touch button). I intend to use Cypress CPU, for example CY8C21434-24LTXI. But if it will be so hard ro  hardware and software desing, I can use CapSense Controller and Cpu.
ETRO_SSN583
Using a PSOC like the PSOC 1 familiy, or more recent PSOC 4 family,
is quite doable to handle both CPU and Capsense in one part. The PSOC
4 family has been recently expanded as well with PSOC 4M, which adds
DMA to the capability, as well as additional programmable hardware blocks,
UDBs. And the PSOC 4 BLE which brings Bluetooth wireless capability to
designs.
http://www.cypress.com/psoc4/?source=CY-ENG-HOMEPAGE&medium=Body-Products
http://www.cypress.com/psoc4ble/?source=CY-ENG-HOMEPAGE&medium=Body-Products
http://www.cypress.com/?id=5509
PSOC 4 element14.com
S No
Date
Project Title
1
01-May-2013
Simple Blinking LED
2
02-May-2013
CapSense Slider Example
3
03-May-2013
PSoC 4 Pioneer Kit Annotation Library
4
06-May-2013
USB-UART utility
5
07-May-2013
USB-I2C Utility
6
08-May-2013
Danger Shield with Light Sensor Control
7
09-May-2013
Danger Shield with 7-segment display
8
10-May-2013
Danger Shield Buzzer of Doom
9
13-May-2013
Graphics LCD Display
10
14-May-2013
LCD - Rotating Cube Demo
11
15-May-2013
GLCD Paddle Game
12
16-May-2013
Pioneer Board Oscilloscope
13
17-May-2013
CapSense Button & LED Control with Bridge Control Panel
14
20-May-2013
What was the value? - LED Memory Example
15
21-May-2013
CapSense Proximity Detection
16
22-May-2013
Proximity Theremin
17
23-May-2013
2-Channel OScope with GraphicsLCD
18
24-May-2013
'Catch the Shells' Game with ColorLCD Shield
19
28-May-2013
LED Memory! Part Deux. Just Deux it!
20
29-May-2013
Starter Designs
21
30-May-2013
Fractional Frequency Synthesizer
22
31-May-2013
“Kill The Ghost” Game
23
03-Jun-2013
tinyprintf Example
24
04-Jun-2013
XBee Router Loopback Example
25
05-Jun-2013
XBee Direct IO
26
06-Jun-2013
XBee API RxTx Example
27
07-Jun-2013
XBee RGB CapSense Control
28
10-Jun-2013
“WiFi? Why Not!” Arduino WiFi Shield Example
29
11-Jun-2013
Bluetooth Home Automation System
30
12-Jun-2013
Bluetooth with GLCD
31
13-Jun-2013
Ethernet Shield
32
14-Jun-2013
More Relay!
33
17-Jun-2013
Sweet Music Everywhere! MIDI Shield
34
18-Jun-2013
Resistive Touch Example
35
19-Jun-2013
UART, I2C, and SPI Joystick Example
36
20-Jun-2013
What? I can use the PSoC 5LP too?
37
21-Jun-2013
PSoC With Friends! Word Scramble Game
38
24-Jun-2013
Ultrasonic Distance Measurement
39
25-Jun-2013
Two PWMs for the price of one
40
26-Jun-2013
Pioneer PnP Sensors
41
27-Jun-2013
Thermistor Example
42
28-Jun-2013
Hangman Game
43
01-Jul-2013
Rise of the Machines (Rolling Robot)
44
02-Jul-2013
Run Away Run Away! (Proximity Robot)
45
03-Jul-2013
Stepper Motor Example
46
05-Jul-2013
“Paint The Night” Accelerometer Example
47
08-Jul-2013
Obstacle Avoider Robot
48
09-Jul-2013
Walk The Line! Robot Example
49
11-Jul-2013
Android Device Controlled Robot
50
12-Jul-2013
SD Card Example
S No
Date
Project Title
51
15-Jul-2013
Music Player
52
16-Jul-2013
Strike A Pose! Digital Camera
53
17-Jul-2013
PSoC Eye
54
18-Jul-2013
Custom Component 4x4 Keypad
55
19-Jul-2013
Parallel to Serial UDB Component
56
22-Jul-2013
Accelerometer Level
57
23-Jul-2013
Digital Audio From A Single Pin
58
24-Jul-2013
An Introduction to Processing
59
25-Jul-2013
But Wait There’s More! Single PWM with 3 Outputs
60
26-Jul-2013
PSoC 4 Mini-Billboard
61
29-Jul-2013
Nokia 5110 LCD Interface
62
30-Jul-2013
Ready…Set…GO! PSoC Stopwatch
63
31-Jul-2013
Some Like it Hot! PSoC Thermostat
64
01-Aug-2013
Workspace Organization using PSoC Theromostat
65
02-Aug-2013
New to PSoC or the Pioneer Kit? START HERE!
66
05-Aug-2013
LED Blinky Revisited
67
06-Aug-2013
PSoC 4 Getting Started Lab 1 (LED Blinky)
68
07-Aug-2013
PSoC 4 Getting Started Lab 2 (PWM LED)
69
08-Aug-2013
PSoC 4 Getting Started Lab 3 (CapSense UART)
70
09-Aug-2013
PSoC 4 Getting Started Lab 4 (ADC)
71
12-Aug-2013
Get Your Motor Runnin’!
72
13-Aug-2013
TFT Touchscreen Shield
73
14-Aug-2013
TFT Touchscreen Tic-Tac-Toe Game
74
15-Aug-2013
PSoC Creator Training 110
75
16-Aug-2013
PSoC Creator Training 111
76
19-Aug-2013
PSoC Creator Training 112
77
20-Aug-2013
PSoC Creator Training 113
78
21-Aug-2013
PSoC Creator Training 210
79
22-Aug-2013
PSoC Creator Training 211
80
23-Aug-2013
PSoC Creator Training 212/213/214
81
26-Aug-2013
NFC/RFID Shield
82
27-Aug-2013
RFID Reader and Writer Project #2
83
28-Aug-2013
Raspberry Pi Integration
84
29-Aug-2013
State Machines in PSoC 4
85
30-Aug-2013
UART Bootloader in PSoC 4
86
03-Sep-2013
GPS Algorithm
87
04-Sep-2013
Gas Sensor Example
88
05-Sep-2013
Simulation of Gas Sensor Example
89
06-Sep-2013
GPS Example
90
09-Sep-2013
Comparator Example
91
10-Sep-2013
Infrared Remote Control
92
11-Sep-2013
Serial Communications Examples
93
12-Sep-2013
4 Channel Multiplexed Comparator
94
13-Sep-2013
Opamp Dynamic Gain
95
16-Sep-2013
Hibernate and Stop Power Modes
96
17-Sep-2013
P4 Light Sensor Project Design
97
18-Sep-2013
Rice Cooker
98
19-Sep-2013
Thermal Printer
99
20-Sep-2013
I2C Pass Though 'Smart Wire'
100
23-Sep-2013
PSoC 4 Time Square Billboard
