CY8CMBR3116 Configuration Write Cycles Limit?
I have not seeing anything about the number of write cycles allowed on the CMBR3116 configuration. Is it necessary to limit the number of writes to the device for configuring it? In our application it is needed to change the settings fairly often, and I wanted to check that we will not see issues dow the road since the settings are in non-vol memory.
Bob_Marlowe
Level 10
Level 10
See datasheet. Flash endurance is listed with 100K Cycles
Bob
Bob_Marlowe
Level 10
Level 10
Bob
