lyz3083718
5 sign-ins First reply posted First like given
I just bought the CY8CKIT-002 used to connect the CCG3PA. The light of the status on CY8CKIT-002 kit was working show  yellow light. But our PSoC Programmer software shows failed connect with our CCG3PA board or maybe show other problems on follow picture. Would you like to give me some advice to fix that?  Thank you
Rakshith
Hi @lyz3083718
Can you please let us know if you have any other tools like Bridge Control Panel open which might be using the MiniProg3 device? From the error, I see that the PSoC Programmer is unable to open the MiniProg3 port. If you have PSoC Creator open, please close that too and then try connecting in PSoC Programmer.
Restarting the PC and then trying might also help.
Thanks and Regards,
Rakshith M B
Oh,the programmer kit was connected on programmer software successfully. Thank you.
But i found i could not program the hex file into my CCG3PA device. The screenshots shown below from Psoc programmer software. The hex file was generated from Psoc Creator with mode kits CTPD3175 programming.
The programmer software can connect with the kit. But from below the pricture, that look likes no ack from CYPD3175 chip. 4A149A28-750B-42fe-A84B-C4935503DF1E.png
