I use CY8C21534 for a project, how do I change the interrupt priority of CSD?
In PSoC 1, the interrupt vector table is a lookup table that maps interrupt vectors to their corresponding interrupt service routines (ISRs). Each interrupt vector has a corresponding priority level, and the priority level is determined by the position of the interrupt vector in the interrupt vector table.
Each digital PSoC block has its own interrupt priority and vector. A row’s position in the array determines the relative priority of the digital PSoC blocks within the row. The lower the row number, the higher the interrupt priority, and the lower the interrupt vector address.
