JaKi_2386966
I am using CY3280-20x66 Universal CapSense  Controller.The default I2C pin is P[1]0-P1[1].I complied the example program.It works well.I can get data form Bridge Control Panel Software by usbing CY3240-I2USB Board.But I want to use another pair of I2C pins P[1]5-P1[7].I have changed the paremeters of EzI2Cs in the same project.And I connected I2USB to J2.But it doesn't work.What should I do to make it work except changing the I2C pin in the Parameters window of EzI2Cs?
SampathS_11
250 sign-ins 250 solutions authored 5 questions asked
You will need to solder R17 and R20 using 100 ohms or less.
Sampath
SampathS_11
Sampath
