Hello everyone,
                      iam new to psoc and iam facing error :  Build error: 'i2c_sendbyte': requires ANSI-style prototype
THIS IS THE CODE
#include<project.h>
#include"i2c.h"
uint8 i2c_Send(uint8 Address,uint8 *Data,uint8 Num)
i2c_start();
//-- Send Addresss
i2c_sendbyte(Address & 0xFE);   //-- Lowest bit = 0 => WRITE    //error line
if(!i2cgetack())
  i2cstop();
  return(0);
while(Num--)
  i2c_sendbyte(*Data);
  if(!i2cgetack())
   i2cstop();
   return(0);
  Data++;
i2cstop();
return(1);
uint8 i2c_Read(uint8 Address,uint8 *Data, char Num)
i2c_start();
//-- Send Address
i2csendbyte(Address | 0x01);   //-- Lowest bit = 1 => READ
if(!i2c_getack())
  i2cstop();
  return(0);
while(Num--)
  *Data=i2c_getbyte();
  Data++;
  if(Num > 0)
   i2c_sendack();
i2c_stop();
return(1);
uint8 i2c_getbyte(void)
char count,Byte=0;
int delay;
SCL_Write(0);
SDA_SetDriveMode(SDA_DM_OD_LO);
for(delay=0;delay<I2CCLOCKLOW;delay++);
//i2cdelay(I2CCLOCKLOW);         //-- Minimum Clock Low Time
for(count=8;count>0;count--)   //-- Read 8 bits of data
  Byte=Byte <<1;
  SDA_SetDriveMode(SDA_DM_DIG_HIZ);
  if(i2creadbit())
   Byte +=1;
return(Byte);
char i2c_readbit(void)
char Data=0;
int delay;
//i2cdelay(I2CDATASETTLE);       //-- Minimum Clock Low Time
  for(delay=0;delay<I2CDATASETTLE;delay++);
SCL_Write(1);
//i2cdelay(I2CHALFCLOCK);        //-- 1/2 Minimum Clock High Time
  for(delay=0;delay<I2CHALFCLOCK;delay++);
if(SDA_Read() !=0 ) Data=1;           //-- READ in the data bit
SCL_Write(0);
return(Data);
void i2c_sendack(void)
  int delay;
//--- Send Ack to slave except for last time ---
//i2cdelay(I2CDATASETTLE);      //-- Give it time to settle
i2cclock();                   //-- Pulse the clock
//i2cdelay(I2CDATASETTLE);      //-- Gap between next byte
//************** END OF i2csendack
void i2c_stop(void)
  int delay;
  //-- Generate Stop Condition --
SCL_Write(1);
//i2cdelay(I2CSTOPDELAY);
  for(delay=0;delay<I2CSTOPDELAY;delay++);
void i2c_start(void)
int delay;
//data goes low with clock high - start condition
/*void i2c_delay(int delay)
int i;
for(i = 0;i < delay;i++);
void i2c_sendbyte(uint8 Byte)
char count;
int delay;
SCL_Write(0);
for(count=8;count>0;count--)   //-- Send 8 bits of data
  if( (Byte & 0x80)== 0)        //-- Get the Bit
                  //-- Ensure Port pin is low
  else
             //-- Release pin if bit = 1
  Byte=Byte<<1;                 //-- Shift next bit into position
  //for(delay=0;delay<I2CDATASETTLE;delay++);
  SCL_Write(1);
// for(delay=0;delay<I2CCLOCKHIGH;delay++);
  SCL_Write(0);
  //for(delay=0;delay<I2CCLOCKLOW;delay++);
//SDA_TRIS=I2CHIGH;              //-- Release data pin for ACK
void i2c_clock(void)
//int delay;
// for(delay=0;delay<I2CDATASETTLE;delay++);
SCL_Write(1);
//i2cdelay(I2CCLOCKHIGH);        //-- Minimum Clock High Time
SCL_Write(0);
//  for(delay=0;delay<I2CCLOCKLOW;delay++);
char i2c_getack(void)
  int i,j;
  int dat;
  int delay;
SCL_Write(0);
SCL_Write(1);
//i2cdelay(I2CHALFCLOCK);          //-- wait for 1/2 the clock pulse
//i2cdelay(22);          //-- wait for 1/2 the clock pulse
for(i = 0;i < 2000;i++)
for(j = 0; j<10;j++);
dat = SDA_Read();
if(!dat)
break;
//if(SDA_Read())                          //-- sample the ACK signal
if(dat)                          //-- sample the ACK signal
  return(0);                      //-- No ACK so return BAD
//i2cdelay(I2CHALFCLOCK);          //-- Else wait for rest of clock
SCL_Write(0);                 //-- Finish the clock pulse
return(1);
/* [] END OF FILE */
please help me
Bob_Marlowe
Level 10
Level 10
Can you please post your complete project so that we all can have a look at all of your settings. To do so, use
Btw:
I2C_Start() (capital "S") and other APIs
Bob
Bob_Marlowe
Level 10
Level 10
Btw:
Bob
I solved above error.when i solving above error new error comes.i tried too many times to slove but i can't.Actually iam creating new i2c component based on my project.when i debugging i2c.c files it show error
Build error: PARSING SOURCE-FILE PREPROCESSOR: MACROS TOO NESTED .
kindly let me know what does this error mean. How to rectify this.
Building a new component is not as easy as you did. Read the "Component Author Guide" to learn how it is done. I would suggest strongly to use the provided (and tested!) components.
The error you get results from a multiple expanding of i2c.h. Look at the generated headers to see how this is avoided uzsing a common way.
Bob
