I am looking for example designs which uses the UDB in 5LP to work closely with the CPU.
I need to write 32b data to UDB and read from result from the UDB. My verilog in UDB will do some custom computation. The closest I saw on the Cypress is the fan control but it uses functions like FanController_GetActualSpeed, is that an API or do I have access to the source codes?
Are there any ref designs which uses the registers in UDB like memory mapped registers?
Thank you!
PSoC 5LP
Welcome in the forum.
Start here for an example and do not forget to look into Brad's blog.
There are no memory-mapped registers in the UDBs but you can address the (few) registers in an UDB-based component directly.
Bob
Bob
That's cool Bob. Thank you.
