I have a CAN based Bootloader and I managed to flash a PSOC5 board with specific code. It works as expected until I disconnect the power supply. Then the bootload process remains in the WAIT_Forever state even though I set the Bootloader component to wait for command a specific time (5 seconds).
I think my problem is related with this thread Serious bug in bootloader component.  Is there a workaround? I tried to add CySetTemp() in bootloader project before CyBtldr_Start() and it does not works.
Issue might be due to the custom Bootloader functions which are being used.
Hima
himam_31
Are you using the latest version of Bootloader component?
Hima
I`m using PSOC Creator 4.1 with the Bootloader Component v1.50. Here is the attached bootloader project.
Can you try with PSoc Creator 4.2 and the latest version of Bootloader 1.6.
Hima
Hi dima,
Thanks for your reply. I updated my projects with Psoc 4.2 and bootloader respectively bootloadable to v1.60 but unfortunately it still does not work. The Bootload process completes, application is working after bootload complete, and after reboot again remains in the wait forever loop... I don`t know how to get around this
Any other ideas?
Hima
