I have a PSOC5LP to which I update the FW by sending it from a Host. I want to verify that the application's .cyacd file is correct BEFORE I start sending it to the PSOC5 bootloader line by line (from what I've seen in the bootloader API, the verify application command checks it against the checksum stored in the P5LP's own flash, so it doesn't work for me). Is there any checksum or CRC information (of the entire application) in the .cyacd file? It's the only way I can think of to check before.
Thanks in advance!
PSoC5 LP MCU
- checksum cyacd
Hi @naldorinho ,
Please let me know the MPN you are using in your project.
You can refer the below document for information about .cyacd file.
https://www.infineon.com/dgdl/Infineon-AN68272_PSoC_3_PSoC_4_PSoC_5LP_and_PSoC_Analog_Coprocessor_UA...
Thanks and regards,
Sidramesh
