Nov 22, 2018
01:30 PM
Nov 22, 2018
01:30 PM
Hello !
I want to filter with a bandpass filter a sinusoidal signal of 800HZ distorted by a noise.
How can I do this the easiest way?
How can I calculate capacitor values? ( I have studied quite a lot the pdf with the bandpass and how the switched capactors works.
I would appreciate your help a lot.Thanks
Labels
PSoC 1
PSoC 1 Device Programming
05:40 PM
Nov 22, 2018
05:40 PM
In PSoC Designer each user module has a independent datasheet, the BPF2/4 user module datasheet explained how to use this module in detail, tools like BPF2 Design.xls/BPF4 Design.xls and PSoC Designer’s built-in Filter Design Wizard is available for you to design your own filter easily.
