Hi There
I would appreciate if someone from where I can get this info ,because opamp 1.90 only give that info for Psoc 3.
Thanks in advance.
PSoC 5 Architecture
PSoC 5LP
- op amp spec
Hi Alex,
PSoC3 and PSoC5lp has same circuit for op-amp. So they have the same specs for op-amp.
Roy
Please check the component datasheet . Both details are available there.
AOL
Noise density
VSRS
Hi VSRS
Thank you so much for you answer .
What you say is right for en ( input noise density).
Avol =90 is at page 9 of data sheet at it belong to PSoC3 info.
So I am wondering if the same value is the valid one for both vesion of PSoC.
At page 13 start the DC and AC characteristics for PSoC 5LP and ithere is no mention to AVOL.
Again, thank you very much
Berst regards,
Alex
Hi Alex,
Roy
Thank you Roy !
Anyway the spec sheet is a little bit confusing because there are the same info for both devices with different values.
For example you have SR and GBW with different values,
I am wondering which are the GBW for the different power modes for the case of PSoC 5LP.
Any way thank you very much for your answer.
Hi Alex,
The opamp need update for PSoC 5LP Characteristic, will be done in the future version of the document.
Alternatively, you can look at the PSoC 5LP device datasheet http://www.cypress.com/file/45906/download for Opamp DC/AC Specifications.
Roy
