Hello everyone,
I'd like to create an arbitrary wave type from a file using the WaveDAC8.
The datasheet of the component doesn't give detailed explaination how to proceed and
there is also no explaination about the meaning of the numbers (255 1 246 253.....for instance) we should put into file.
Thanks for your help
Vasanth
Hello Mohamadou,
The Wavedac component is created using a VDAC component and a DMA block. The 8 bit VDAC can take values from 0 to FF(255) which will be passed with the help of the DMA clocked at the rate your require. This is how the waveform is generated. I hope this explains what is the significance of the values you give. You have an option to draw the waveform you need in the component.
VSRS
Vasanth
Hello Mohamadou,
VSRS
Thanks a lot, VSRS!
That was really helpful.
