Is it possible to implement an analog circuit (transistor level) in the PSoC 5LP kit. If not , whether there is any other kit in which I can implement an analog circuit (eg. Transconductance amplifier in transistor level).
Bob_Marlowe
Level 10
Level 10
The analog components in PSoC are pre-fabricated and do not allow configuration on transistor level.
Bob
HeLi_263931
Level 8
Level 8
100 solutions authored 50 solutions authored 25 solutions authored
If you want to work on transistor level, you will need discrete transistors. AFAIK there is no IC that allows doing this in a single chip (in a programmable way).
Why do you want to do that?
Bob_Marlowe
Level 10
Level 10
Bob
