AnHe_1053556
Is it possible to get the Altium Source Files of the Battery Charger EBK?
Vasanth
The gate drivers and MOSFETs are an overkill in the design. You can check the following components.
Dual N-channel mosfets
Gate driver
Here again the gate driver is is slightly an over kill, because of high source current drive capabilility of >4A, which is not required in the application. You can go for a lower current drive capable gate driver based on turn ON/OFF requirements of the mosfets.
Vasanth
Vasanth
Unfortunately source files are not available for battery charger EBK. Additionally the design only demonstration purpose and not optimized for design. It is advised to develop a custom board at your end for your application. If you need any advice we can help in that.
Vasanth
AnHe_1053556
Thank you for your answer. Can you recommend something for a redesign? What would you improve in a new design?
Vasanth
Gate driver
Vasanth
