May 29, 2023
01:06 AM
May 29, 2023
01:06 AM
I'm having trouble with programming tip5 and tip6 of "AN60580 - SIO Tips and Tricks in PSoC® 3 / PSoC 5LP". Could you please suggest a program for reference? The PDF file states that there is a project "SIO_HalfWaveRectifier".
Labels
PSoC3 MCU
PSOC5 LP MCU
02:33 AM
May 29, 2023
02:33 AM
https://www.infineon.com/cms/jp/search.html#!term=AN60580&view=all
You should be able to download the AN60580 sample code from the page you searched for at the URL above.
You may need to update your project and re-build it since the version of PSoC Creator is older and the code is for PSoC3.
May 29, 2023
04:36 PM
May 29, 2023
04:36 PM
Thank you for your response. I was able to find the program I wanted.
