ADC_filtrer_DMA
feme_285141
Level 4
Level 4
problem to transfer data from one filter to the USB-UART with DMA
How to read the data with putty ??
you can use the printf () function ???
Bob_Marlowe
Level 10
Level 10
You are transferring binary data via your USBUART interface which you will not see displayed correctly in PuTTY. You need first to convert the binary 16-bit numbers to ascii characters. This cannot be done using DMA, you will have to read the results number-by-number, convert them using sprintf() and sending the results to USBUART.
Bob
rola_264706
Level 8
Level 8
        Please Post your project so we can help you resolve your issue.
feme_285141
Level 4
Level 4
HERE THIS DOCUMENT
Bob_Marlowe
Level 10
Level 10
Bob
feme_285141
Level 4
Level 4
the problem is making the interruption with DMA to bring the information to USB_UART. Can someone help me with this I would appreciate.
Bob_Marlowe
Level 10
Level 10
keep interrupt handlers short! Whenever possible, just set a flag and react on it in the infinite loop in main().
Best practice is to use the isr's or component's StartEx() function to connect the handler to the interrupt. Look into the "System Reference Guide" to be found under Creator's help (Search for "Cy_ISR")
Bob
