I am trying to implement a notch filter with 50 Hz. I followed the example shown in Filter_ADC_VDAC_polled and configured the same. However not getting results. Can anyone help
PSoC 5LP
Sorry guys .. its fixed... I should connect EOS to drq instead of EOC....
I fixed for WaveDAC8_1_Start(); but still no results ..
it seems necessary to use Filter_1_STAGEAH_PTR for DMA not Filter_1_STAGEA_PTR
103 CyDmaTdSetAddress(tdChanA, LO16((uint32)ADC_SAR_1_SAR_WRK0_PTR), LO16((uint32)Filter_1_STAGEAH_PTR));
Thanks Pavloven !! I have corrected it and its fixed. But it working for 128 filter taps. If I reduce the number of taps, significant amount of 50Hz appears at the output. I have to add one more stage and the total combined size of all filters can be up to 128 taps.. What can be the solution??
Apparently you have to use OPAMP (TIA, PGA) and external components
for constructing the prefilter.
eg danaaknight gave a link to TI Filter Designer.
Thanks for the suggestion!! I was trying to avoid off chip components. Anyway it would be essential some times. Thanks for your time and attention !
dhans,
Another approach can be to utilize 50 Hz notch filter in code:
https://www.fpgarelated.com/showarticle/935/harmonic-notch-filter
Thanks for your suggestion !! I shall go through this one.
