Hello, Has anybody got the AD9833 component code and managed to create a frequency sweep?, the parameters I require are 1Hz to 60Khz at a rate of 30Hz, possibly adjustable by an encoder,
Kind regards
PSoC 5LP
IaCa,
The low frequency limit of 1Hz, and sweep rate of 30 Hz do not match. At sweep rate F_sweep=30 times/sec, the instantaneous frequency (in)accuracy for any output frequency is already 30 Hz. For example, the 1 kHz output is defined with accurcy 1kHz+/-30Hz. Therefore, to make any sense, the F_min should be larger than 30Hz (e.g. F_min=1kHz). Also other parameters are missing, like required number of frequency steps and accuracy.
What output waveform needed: square or sine?
What the encoder should control? Sweep frequency? In what range?
It may be possible to accomplish the goal by using PSoC internal frequency generator, like DDS24 or DDS32. Please take a look at these threads:
DDS24: 24-bit DDS arbitrary frequency generator component
Re: Generate variable frequency
/odissey1
IaCa,
/odissey1
