PSoC™ 5, 3 & 1
himc_284346
New Contributor II
I need to transfer 32 bit over SPI. How can I do that?
HeLi_263931
Honored Contributor II
Just configure the SPI master to 8 bit data width, and send 4 bytes. Nothe that, when the clock is fast enough, you need to control the slave select line manually (otherwise it might go high inbetween consecutive bytes).
