Hello
I need to develop wireless system that should be transmit serial data from  PSoC4 to my PC.
Is it possible with xbee module. please guide me
rola_264706
Level 8
Level 8
Vead: here is your program. I have updated it to Psoc Creator 3.3 SP1. It is for the Xbee and should work. I don't have an  Xbee module so I can't try it out.
look at module Is it type of module that can be interface with psoc4 ?
rola_264706
Level 8
Level 8
I didn't change the device to the 049. It uses a 4200 Pioneer kit.
rola_264706
Level 8
Level 8
Here is the program with the CY8CKIT-049-4200 device.  Change the dependencies to agree with your system.
EvPa_264126
Level 7
Level 7
500 replies posted 250 replies posted 100 likes received
at your pictured CC2500 module
A little bit of this module in this topic
rola_264706
Level 8
Level 8
        It looks like TI has a test program for this part and it displays the code and if you installed it . You could then place this code into your program. I think the Xbee program was based on a UART code not SPI. I'll check it and see. This device is much more complex than the orginal Xbee so it looks like it will take some time to get it too work.
yes I tried but I don't understand how to interface that zigbee module to Psoc 4 kit.  Zigbee module can be receive or transmit data  so can we send or receive data from PC to Psoc4
