what do you mean by resource limit: maximum status cells exceeded??
This error generally occurs when you are using UDB based components in your application especially when the components present in the schematic requires more UDB resources than available in the particular device.
The UDB based components are generally made of different sub blocks as mentioned in the below image:
For more information on UDB and its details please go through device's architecture TRM along with the links present in the attached document.
Hope this helps! Else please update.
Ganesh
Ganesh
