PSoC™ 4
moshc_4060821
New Contributor II
i am working with Psoc4 Ble pioneer kit.
i want to generate a WDT based interrupt after every hour. so to do that i have i have used global signal component.
this is my code
CY_ISR(WDT_ISR_handler)
    WDT_ISR_ClearPending();
    HW_Init();
    /* Starts RTC component */
    RTC_Start();
    /* Set RTC time update period */
    RTC_SetPeriod(1u, SYSTICK_EACH_1_HZ);
    RTC_ClearAlarmStatus() ;
    RTC_SetAlarmHandler( alarm_handler ) ;
    RTC_SetAlarmMask( RTC_ALARM_SEC_MASK ) ;
    WDT_ISR_StartEx(WDT_ISR_handler);
    for(;;)
please find attached screen shots for WDT2 clock configuration.(currently i am testing it with only 4 seconds)
so my problem is first time interrupt is generated after 4 seconds but then it could not clear and the pending register or something.
please guide me.
moshc_4060821
New Contributor II
hi
i have solved the problem.
this is my code.
      CySysWdtClearInterrupt(CY_SYS_WDT_COUNTER2_INT);
    HW_Init();
    RTC_Start();
     /* Enable WDT0 counter */
    CySysWdtEnable(CY_SYS_WDT_COUNTER2_MASK);   // WDT=PeriodicTimer
    WDT_ISR_StartEx(WDT_ISR_handler); // Start ISR for pin toggle
    CySysWdtEnable(CY_SYS_WDT_COUNTER2);
    for(;;)
thanks for helping.
Mohit
